remote stopped working
Old 11-03-2011, 11:51 AM
sabin_chicago
sabin_chicago's Avatar
Default remote stopped working
hello
Here is the story. Like 2 days ago the key-less entry remote stopped working; it happen just suddenly. It's a 01 mustang.
Anyone encountered this?
I've replaced the battery inside the remote, but still the same.
I might need a new remote? What I noticed also when it was working is that I could open the car from a fairly small distance away.
thanks
sabin_chicago is offline
Old 11-03-2011, 08:28 PM
Chromeshadow
Chromeshadow's Avatar
You might have got a bad battery, you may have bad connections inside the remote.
When you open the remote to replace the battery, you can clean all of the battery connections with a pencil eraser. The switches can be cleaned to, use real light pressure on them.
You can get a new remote for about $50.00 from the dealer.
Chromeshadow is offline
Old 11-03-2011, 09:17 PM
sabin_chicago
with a new remote the dealer will have to reprogram it, right?
Old 11-04-2011, 08:47 AM
jesse1125
jesse1125's Avatar
No, I got a new remote from ebay and you can program it to your car yourself. The new remote should come with instructions. It's real easy.
Since my car only came with one remote I bought another so my wife will have one too.
jesse1125 is offline
Old 11-04-2011, 08:51 AM
jesse1125
jesse1125's Avatar
Here is just an example. You can buy a new one for less then $15
http://www.ebay.com/itm/NEW-FORD-MER...item415d07ab6e
Old 11-04-2011, 06:02 PM
belairbrian
belairbrian's Avatar
Read through this thread. It has links to the programming instructions as well as pictures you'll need to locate the programming plug.
https://mustangforums.com/forum/v6-1...ess-entry.html
belairbrian is offline
Old 11-04-2011, 06:43 PM
jesse1125
jesse1125's Avatar
The OP has a 2001. There is no need to find any plug to jump any wires. You just sit in the drivers seat and program the remote to your car. It takes about 1 minute and you are done. Just follow the instructions that come with the remote. All you need is your key, the new remote and the instructions that tells you in order the steps of when to turn the key and when to push the buttons.
Old 11-04-2011, 09:48 PM
belairbrian
The link in the other thread provides instructions for all cars.
Old 11-04-2011, 11:23 PM
sabin_chicago
thank you guys for the replays. I'll get a new one.
Old 11-05-2011, 08:24 AM
jesse1125
jesse1125's Avatar
I see it now. You added this link in the thread which tells how to program any year car like you said.
http://www.programyourremote.com/cla...yAd.asp?id=539
When you said in post #6; "pictures you'll need to locate the programming plug." I didn't want the OP to think he has to find a programming plug to program his new remote.
All is well and I think Sabin knows what to do.
Quick Reply: remote stopped working
