axel swap and shift kit!
i got a couple of question about an axel swap: a everyone is telling me that i should get a gt that it will run my gears lower , is that worth it? b. is it diy job? i got a good garage that i can do the work in and some help. the other question is whats the best shift kit or a good trusted brand that wont **** up my tranny in the long run its a 97 v6 3.8 thank you in advance.
simply switching to a gt rear end doesnt guarantee that you will have a different gear ratio. you will have to do a little more research and maybe pick up a rear end that already has the gear ratio that you want. Other than that it can be a diy job. as for a shift kit, i would recommend the j-mod and tuner to firm up the shifts
i personally just upgraded to an 8.8", got the stock differential built up a little bit and got the gear ratio bumped up a little but to 3.55. If you are keeping the 7.5" then 3.73 and 4.10 are going to be your options. depends on if you want quicker or even more quick
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
