Passanger side Headers 01 v6
Old 05-12-2012, 06:45 AM
austin184
austin184's Avatar
Default Passanger side Headers 01 v6
Im trying to replace my headers with some new bbk shorties but iv having a bit of trouble on the passanger side.
i cant get the egr valve off the header so i was going to pull it out as one piece .but what are the hoses above the headers for it runs from on side of the motor all the way around it and beseide the ac coil
.i dont want to unhook this hose and it fluid start pooring out or anything so i need to know what it is .Thanks
austin184 is offline
Old 05-12-2012, 01:20 PM
neo8222
neo8222's Avatar
Your post is rather confusing, especially because there is no "ac coil" under the hood. Are you talking about the 2 rubber hoses that have clamps holding them in place going into the firewall right next the each other? If so you those are coolant lines that are going to the heater coil.
neo8222 is offline
Old 05-13-2012, 10:37 AM
austin184
austin184's Avatar
im not sure what it is its the 2 hoses above the header i know one hoes is for the ac and there is also a rubber hose i didnt want to unhook it unless i knew what it was because i didnt want fluid to rush out or ruin my AC
Old 05-13-2012, 04:28 PM
NeoTokyo
NeoTokyo's Avatar
An A/C system wont run through a rubber hose, its a sealed system that uses metal lines, the pressure is simply too great.
The two small rubber hoses that you are talking about are on the EGR tube itself, they are vacuum hoses and nothing will spill out. Thats the only thing I can figure that you are talking about.
Use some PBlaster on the nut for the EGR on the header and let it soak in for about 15 minutes, then come back and hit it again.
If you still arent sure, snap a pic and let us see what you are talking about.
NeoTokyo is offline
vargas
06-17-2017 12:17 PM
Roxon68
03-17-2016 08:13 PM
trashxtrash
09-20-2015 10:49 PM
ctgreddy
09-20-2015 08:35 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: Passanger side Headers 01 v6
