99 Mustang will not start
Old 03-21-2014, 06:28 PM
jcrane
jcrane's Avatar
Default 99 Mustang will not start
Hello, my son's 99 V6 Mustang will not start. It seeme to be a fuel problem. I tried checking the fuel pressure at the schrader valve but there doesn't seem to be any pressure. I removed the valve core and turned the key on and nothing will come out of the valve. We also replaced the fuel filter but that didnt help. I can't hear the pump either. Is there a way to check that the pump is good/bad before pulling the the tank? It will run on some either but as soon as the either is gone it dies.
The car was running but hasn't been driven much in the last few months, any ideas?
Thanks
jcrane is offline
Old 03-21-2014, 08:56 PM
edwin108
edwin108's Avatar
You could try beating on the fuel tank while cranking the engine.
edwin108 is offline
Old 03-21-2014, 11:19 PM
Daehawk
Daehawk's Avatar
Well if you turn the key to ON but not start it and dont hear anything and you have no fuel pressure that pretty much says fuel pump...or fuse.
EDIT: One other thing is you might try checking the inertial switch in the truck and see if that some how was tripped.
Daehawk is offline
Old 03-22-2014, 02:25 PM
jcrane
jcrane's Avatar
the inertia switch seems ok, the fuse isnt blown so I guess we pull the tank......
Thanks
jcrane is offline
ShaneB26154
35
03-04-2021 04:05 AM
Urambo Tauro
09-07-2015 12:47 PM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 99 Mustang will not start
