2001 7.5 Rear End Swap Questions
Old 07-10-2014, 06:24 PM
papetti51
papetti51's Avatar
Default 2001 7.5 Rear End Swap Questions
Hey guys i am new to the forum and i have been thinking about swapping out the gears in my v6 mustang the thing is i really want to switch to an 8.8 rear end because my dad insists it will be easier for us to work on and that way i have my old rear end to switch back to when winter comes around as it is my daily driver
but anyways to the question i was wondering if i could fit a 94-98 rear end in my 01 because i cannot find any reasonably priced 99-04 8.8 rear ends within 115 km radius of where i live also my car has ABS so id i could do the switch would i need to find a rear end with abs?
i have seen tons of posts about guys putting 99-04 rear ends in their 94-98 mustangs but none the other way around so i was wondering can i do it without making any major modifications and also if you guys have any suggestion about what gears should put in i would appreciate your input i drive a 2001 automatic mustang v6 with ABS
Thanks For Your Help
papetti51 is offline
Old 07-12-2014, 10:37 AM
PNYXPRESS
PNYXPRESS's Avatar
The 94-98 rear housing will fit. The only issue you will have is it will be narrower than your current rear
Yes you will need abs axles in the new rear
PNYXPRESS is offline
Old 07-13-2014, 01:15 PM
BabyGT
BabyGT's Avatar
Bingo, the 99-04 rear is wider than the 94-98 rear. Wheels will sink in a bit but it will fit. You can compensate this issue with spacers. And as stated you will need to use ABS axles.
BabyGT is offline
Old 07-13-2014, 01:54 PM
mustangman02232
mustangman02232's Avatar
I allways recommend rebuilding what you have with gears and a Detroit true trac, not a fan of taking time/money to swap someone else's headache into my car
mustangman02232 is offline
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
ding56
08-14-2015 02:40 AM
92 5.0stang
08-13-2015 06:46 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: 2001 7.5 Rear End Swap Questions
