2001 Mustang Misfiring / Flashing Service Engine Light
Old 07-23-2014, 02:52 PM
bbjack
bbjack's Avatar
Originally Posted by Derf00
You are contradicting yourself. You want to be frugal yet you're already throwing parts at it hoping to fix the problem (spark plugs). What makes you think it's a plug?
If the problem gets worse when it rains I would go with wires before plugs. Plugs would present the problem all the time and not get better or worse when it rains/doesn't rain.
I just noticed this is a 3.8L. Plug wires are a big culprit on these. Go with Motorcraft wires, not aftermarket. Aftermarkets tend to have incorrect bends on the boots which puts them right on the exhaust manifold and burns them out quicker.
Spray bottle trick on the wires will help find the problem wire(s).
At the same time, I also said that I need to spend what I can to make sure I get it fixed. I however strongly prefer not to go into the 100s right now. $30 on new plugs isn't bad and at least I know I have new spark plugs. Wires will probably be next, which aren't much. I need to do the spray bottle test. I'm hoping I see something!
bbjack is offline
djbigskrilla
09-20-2022 01:04 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 2001 Mustang Misfiring / Flashing Service Engine Light
