New here, exhaust leak from the engine area
Old 04-28-2015, 09:15 PM
bond007
bond007's Avatar
Default New here, exhaust leak from the engine area
So I recently got an '03 v6 convertible, 100K, I bought it knowing the noise due to the outstanding condition of engine, transmission and body in general. Looks to me like a manifold leak. No CELs in dash, just the noise. Is this common for these engines? Any idea what the local Ford dealer will quote? The interesting thing is that I only hear the exhaust leak when the car is started-up from being cold at mornings, then it quiets down as it warms up. Opinions, ideas appreciated...
Thanks
bond007 is offline
Old 04-28-2015, 10:45 PM
jwog666
jwog666's Avatar
the manifolds rust out, the egr tube rusts out, and the manifold studs/bolts break off due to corrosion. inspect and u will find one of the 3 or multiple are causing your leaks. good luck
jwog666 is offline
Old 04-29-2015, 09:10 AM
bond007
bond007's Avatar
Ok, will check this afternoon.
Thanks!
bond007 is offline
Old 05-20-2015, 12:23 AM
bond007
bond007's Avatar
Default Contemplating headers, should I get with the stock cats.?
Looking to get a set of headers instead of factory manifolds for the car. My question is, will the headers, (looking to get BBKs), be too much airflow through the stock cats. than can trigger a CEL? Right now I have no check light, just the manifolds leaking on both sides. I was looking to get these, then eventually getting a catted mid-pipe and the catback exhaust after I do a bit more budget for it.
bond007 is offline
Old 05-20-2015, 06:15 AM
jwog666
jwog666's Avatar
there is no such thing as too much air flow through exhaust, the only thing that will trigger a cel is cat removal and o2 sensor placement
jwog666 is offline
Old 05-20-2015, 11:28 PM
bond007
bond007's Avatar
Ok got it, now another thing. These headers have provision for screwing the EGR tube on the passenger side, but how about for the two little vacuum ports that are on that side? Or would those plug-in to the actual EGR tube?
Thanks
bond007 is offline
Old 05-21-2015, 02:49 AM
petrock
petrock's Avatar
The two vacuum hoses that come out of the EGR tube go to the DPFE sensor. Good luck...
petrock is offline
Old 05-29-2015, 11:23 PM
mustangman02232
mustangman02232's Avatar
If you are going headers I would recommend doing long tubes with you choice of a mid pipe, if you just want to fix the leak then 94-98 manifolds are basically short tube headers
It seems all fords have issues with manifolds leaking, my old v6 did, which I personally put on long tubes, new gaskets/studs, new O2 sensors, a high flow catted H and a 2.5" fatback with flowmaster style chambered mufflers, I was very happy with that set up
mustangman02232 is offline
Hogquad
08-23-2015 05:26 AM
91StangOwner
08-20-2015 11:34 PM
rakesh544
08-19-2015 06:23 AM
11GTBlu
5.0L V8 Technical Discussions
08-10-2015 05:56 PM
Itstbrown
08-09-2015 03:49 AM
Quick Reply: New here, exhaust leak from the engine area
