I could use some ideas
I have a 2000 v6 Mustang, M/T I gave it a tune up, Coil, plugs wires and fuel filter but even before that I would drive about 15 miles or so and it would start to Bogg when i pressed the pedal to the floor, But not all the time I would turn the car off and back on and it would work fine again. any thoughts?
Not a lot to go on for a diagnosis. My advice start simple and progress to more detailed troubleshooting.
Check for a restricted exhaust - simple check for Fords here
Check fuel pressure when the engine bogs vs specs
Scan for any codes present - Is SES light on? (this should be first)
Post back with more detail and the results of above.
Good Luck
Good Luck
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
