2000 v6 mustang having problems starting in cold weather
Old 01-15-2016, 11:00 AM
majcric
majcric's Avatar
Originally Posted by PNYXPRESS
^This. Dont turn a small problem into a giant mess. Sometimes the simplest solutions will fix the problem.
Turning into a giant mess is what scares me. But how to do you avoid this? From my experience some of the smaller problems are sometimes one of the biggest headaches to fix.
majcric is offline
Old 01-15-2016, 12:37 PM
PNYXPRESS
PNYXPRESS's Avatar
Lets start at the beginning. There are only a few parts needed to start the engine
1. Good battery
2. Good starter
3. good coil pack
4. Good spark plugs
5. Good power supply going to each
6. Good fuel injectors
7. Good fuel supply
8. Good air supply.
A. Does the engine turn over strong? If not, check wiring going to starter.
B. Are the plugs firing? If not, check plug wires for fraying or arcing. Also check power going to coil.
C. Does it start easier with the throttle pushed wide open? Check you throttle body and IAC valve for blockage and clean them as well as your filter and MAF
D. How do you know its flooding? Can you smell a heavy fuel smell? Make sure you truly are getting fuel.
PNYXPRESS is offline
Old 01-15-2016, 01:05 PM
Chromeshadow
Chromeshadow's Avatar
Btw, when you start it, do you usually hit the gas? These should start without touching anything except the key. Have you checked the air filter?
Chromeshadow is offline
Old 01-15-2016, 02:07 PM
majcric
majcric's Avatar
1. Good battery
2. Good starter
3. good coil pack
4. Good spark plugs
7. Good fuel supply
8. Good air supply.
I feel pretty comfortable ruling out 1 and 2. The rest of the checklist I'll definitely need to look into. I want to say the plugs are firing since the engine runs great once it is started. They might not be firing quite right though. Will also look into the coil
Once the car throws a fit in the extreme cold the throttle must be pushed to floor with lots of continuous cranking otherwise it will not start. This is the only reason I even touch the gas. Under normal circumstances or warm weather I never touch the gas pedal.
I should have never assumed it was flooding. This I do not know with certainy
majcric is offline
Old 01-15-2016, 02:15 PM
majcric
majcric's Avatar
Originally Posted by Chromeshadow
+1
I usually never do. This is only done as a last result meaning you either hold the pedal to the floor or you can forget the car starting at all.
majcric is offline
Mustanggirl719
01-13-2016 08:48 AM
Rory Fraser
01-12-2016 10:29 AM
RPM2night
12-25-2015 09:30 AM
Toadster
11-23-2015 06:55 AM
loganf1221
11-17-2015 04:01 PM
Quick Reply: 2000 v6 mustang having problems starting in cold weather
