anyone ever get code p1443?
Old 09-09-2006, 02:08 AM
98ponycar
98ponycar's Avatar
Default RE: anyone ever get code p1443?
You're more than likely going to be looking at the EVAP canister purge solenoid. An easy way to test it is to apply vacuum to it, and then apply battery voltage to it. When you apply the voltage, you should lose the vacuum. Sometimes you will have it fail intermittently, so just because it tests fine one time doesn't mean it will the next.
98ponycar is offline
Old 09-09-2006, 10:31 AM
Poobs
Poobs's Avatar
Thanks guys I apreciate the feed back
I saw something under the hood that may be it. Round,black with hoses coming in /out horizontally toward the top and a connector, It is mounted by the passenger side firewall
Poobs is offline
Old 09-09-2006, 08:15 PM
Poobs
Poobs's Avatar
took the little thingy out and with 12 volts it cliks on off sometimes so I beat it with a hammer handle and sprayed some silicone into it. It openend and closed fine on the bench,
I pulled the battery wire for a while now I am waiting for the CEL to go on again.
I read that some problems require several driving cycles to work themselves out of the system or for the light to go on again[:'(]
Poobs is offline
Old 01-10-2007, 01:27 PM
jeffrey138
jeffrey138's Avatar
i replaced the evap purge solenoid & that fixed the code.
jeffrey138 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: anyone ever get code p1443?
