1995 v6- bad engine
1995 v6- bad engine
I have a 1995 mustang that just hit 51,000 miles
the crank shaft bearings went bad recently and my dad had a friend of his check it out
he said it will cost 1500 to 2500 to fix
what should i do.. possiably get a 302 and from where?>
my aol is brianator99
-Thanks
Brian
-Thanks
Brian
RE: 1995 v6- bad engine
no no , No 302!!! it will cost you alot of money in the long run , I would get a split port eninge off ebay or a mustang graveyard for about 500-600 bux and put it in , 195 horses over your 150 would be a def improvement
ORIGINAL: TorchV6
but the split port option is also going to cost you a ton of money just not as much as a 302 swap.
Wow. You guys ramble a lot dont yah?
Truthfully 1500 doesn't sound right for the crankshaft bearings though.....
Nobody seemed to mention just pulling the whole crankshaft out of an earlier model 232. Probably cost you about 150-200 bucks if you get it from a junkyard.
A splitport 232 can be found for about 700-850 and the wiring harness for about 150. But this can be a waste of time as replacing the crankshaft and porting the engine could be about 800 if you do it yourself.
If you are just looking to fix the engine, just go with the crankshaft replace.
If you are looking for more power as well there are the already mentioned options of a splitport engine or the v8. But there are many other options like a 4.2 stroker......
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
