M112 Installation, FAQ, & Discussion
#22
my mod list just keeps growing..
if i wanted to do an h/c/i swap and ultimately m112 just like everyone else here, would it be better to get a mild cam that would work before and after f/i or just wait and get the big stuff but put it all together at once? if that makes sense..
that was in the first post. its $2800. pm matt for buying details
#23
as far as power, enough. im hopin for a little over 300 after im done. its gonna be a daily driver till im out of college so i need a setup that can handle a lot of driving.
also, is there a thread explaining everything about meth injection?(what it is, how it works, how to install it, etc...) if not can someone fill me in?
#24
if you just want 300hp to be happy, than you can just slap it on and get tuned and go.
as far as meth with this setup, i wouldnt do it. i would instead, use the stock blower pulley and a UDP to lower you boost. with that, this would happen....
lower boost
lower boost = less heat
less heat = more room for more aggressive tune
so in turn, lower boost could end up meaning more power
lower boost
#26
If you have a Pro charger, just use it.
And I'm confused about the stock block question. Your sig says you have a Delk made 4.2L. And by stock block to you mean block itself, or stock bottom end?
#27
No my friend wants to use my old motor (stock block and bottem end) and put a procharger or m112. he was asking what would be better on stock motor becaus ethe prices are about the same for ether kit.my old motor has about 130,000 on it.
#28
seeing as no one has busted a stock block or crank yet id say a lot , forged rods and pistons and head studs are the biggest upgrades you need to make.
#29
yea well he dont have alot of money to build up the motor.He just wants to supercharge it and go for a good bit without having to spend a butt load on the motor then another 2800 for the f/i kit.
how much would a stock motor hold? even if it has over 130,000 on it? and hp wise how much would it make on the lower psi (5-10psi)?
