NYstangs build thread place
#22
news~!
mini-update...
started to fix my center console-
couldnt get the **** thing off, and realizred i had to cut the O/D wires again. putting it off until warmer weather.
going to try to make my own lower grill-
EGR delete-
yay bumpers?
hanger kit-
25% UDP
door pulls, exhaust gaskets, tranny filter/gasket
214/214 Cam:
the scoop-
came out pretty good. underside, as you can see, isnt amazing. going to shoot it plan black under there.
oh hey, more wheels!
also picked up a 2.93 pulley
aaaand decided to Mod Saleen a little...
trailer is still snowed in, so I cant start work on it yet. Hopefully picking up the rear soon...
Cleaned up the longtubes-
cleaned vs non- got the rust off:
Coated them, baked them after this:
went to paint my pillar pod, found out that Med. Dark parchment isnt the dark one, apparently.
:fuu:
my blower-
repainted the oval and SVT-
Garage Dog!
mini-update...
EGR delete-
yay bumpers?
hanger kit-
25% UDP
214/214 Cam:
the scoop-
:fuu:
my blower-
Garage Dog!
#25
Should run around 11psi, on TomZac's car he got 10.9 with the same setup.
nothing to the bottomend...yet.
still need:
-the boxed upper to arrive
-belt
-plugs
umm.. yeah. thats it.
#27
11psi...15rwhp per psi...165rwhp over a stock 3.8 plus longtubes and a cam. Correct me if I'm wrong but you might be near the threshold of the stock bottom end.
Either way I'm excited, congrats and good luck
#29
J-
Eaton swap, Longtubes, Cam, 3.55 geard 8.8 rear are all going in, plus supporting mods(fuel system, trans cooler, etc). Also have a shiftkit Ive been split on using, since ive heard a couple horror stories. keeping the interior stock, no major weight reduction.
Ive also been debating an AIS meth kit, but that depends on where i stand financially in may.
hopefully it will hit a 12.99 on slicks/skinnys
#30
12.99 sounds reasonable, are you getting a stall converter at all? that would definitely help with the ET. Good luck with everything. pretty excited to see the outcome, will probably be doing this next year
