Engine Fires Then Dies
Old 04-20-2007, 10:13 AM
BHRS
BHRS's Avatar
Default Engine Fires Then Dies
For the last few mornings I have had a hard time getting my Stang started. I will turn the ignition on and let the fuel pump set/pump up, hit the key and it sounds like normal starting, turn ignition to on/run and the engine dies. I can try to start it again and it fires everytime. When I get to work, I can turn it off and restart it with no problem.
It acts like the ignition is turning off not fuel starvation.
Any ideas???
Thanks!!!
BHRS is offline
Old 04-20-2007, 10:16 AM
tedBalog
tedBalog's Avatar
Default RE: Engine Fires Then Dies
Sounds like an issue with fuel delivery..
tedBalog is offline
Old 04-20-2007, 02:24 PM
pat6674u
pat6674u's Avatar
Check your ground wires, I had a similar problem and it was a loose ground wire causing the ignition to kill.
pat6674u is offline
Old 04-20-2007, 02:39 PM
BHRS
BHRS's Avatar
Which ground wire? Was it at the battery or the many on the chassis?
Thanks-
BHRS is offline
Old 04-21-2007, 03:05 PM
harlanb1
harlanb1's Avatar
I can't say for sure if this will work, but you might want to try disconnecting the car battery
for a few minutes and then reconnecting it. The computer will may have a setting out of wak.
I know my ford f150 would hesitate when starting out from a stop, evan after a complete tune.
I disconnected the battery and reconnected. It quit hesitating after that.
harlanb1 is offline
Old 04-21-2007, 04:59 PM
pat6674u
pat6674u's Avatar
mine was the one on the main chasis by hood strut. It could be any ground wire though, check em all.
pat6674u is offline
Nick Oliver
10-17-2018 04:22 AM
1TUFF302
11-05-2015 04:02 PM
ChampInSD
10-02-2015 04:55 AM
StalkerGT
09-25-2015 02:41 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine Fires Then Dies
