Weird Tail lights goings on and other electrical issues
There is a clicking noise coming from what I would describe as the shifter area/dash when depressing the brake pedal. Any reason why? Is there a relay that might be bad as well?
And I cleared out the gromets that lead down to the engine. Those were gross and clogged.
If you have an automatic that clicking noise is the release for the shifter. If you try to move from park to drive without stepping on the brake it is locked - but step on the brake and you hear a "click" and the transmission shifter will move from park.
I only ask cause I've never heard it before. Anyone have an issue resetting the window? My driver side window wont reset even with holding it down for 2 seconds and up closed for 2 seconds. Auto down works fine. Auto up has a bounce back. There is nothing at the top of the window channel. It will close all the way if held up at the switch manually. Also, it doesn't go down and up when the door opens or closes.
