Bad cats on 07 v6
Old 11-20-2013, 06:16 PM
Farmboy876
Farmboy876's Avatar
Default Bad cats on 07 v6
I need new cats for my mustang, it's fully stock and a shop here in tucson quoted 450 to put new cat in. What's the cheapest route I should take? For that much I could get an aftearket exhaust
Farmboy876 is offline
Old 11-20-2013, 07:05 PM
Nuke
Nuke's Avatar
WHY do you need new cats? what happened to the OE ones and why?
Nuke is offline
Old 11-20-2013, 09:18 PM
Farmboy876
Farmboy876's Avatar
Under acceleration my car would just revv and seem to not go anywhere, I thought it was a tranny problem so I took it to a shop and turns out it's clogged cats. They disconnected my exhaust and took it for a test drive and it ran perfect. Right now I have my o2 sensors out so the little bit of air flow will get me to work everyday until I get new cats.
Old 11-26-2013, 05:30 AM
JJHoover
JJHoover's Avatar
I had magnaflow cats put on mine.
JJHoover is offline
Old 11-28-2013, 11:38 AM
157dB
Cut & Paste Expert
157dB's Avatar
You will be getting a new motor running it with the O2s out of the system...
If it revs, its not clogged cats...
How many miles on this V6 that it has clogged cats?
100,000 miles?
300,000 miles?
A half a million miles?
New mechanic time for you...
157dB is offline
Old 12-03-2013, 06:43 PM
isawitdie86
isawitdie86's Avatar
I just replaced my cats with pypes high flow and I love them.200 from american muscle and 100 for install.def can tell a difference.
isawitdie86 is offline
Old 12-14-2013, 11:45 AM
157dB
Cut & Paste Expert
157dB's Avatar
200 for Pypes is kinda steep...
Pypes are Carp.
157dB is offline
Old 12-14-2013, 01:03 PM
DRAGUL
DRAGUL's Avatar
Check with a Ford dealer. Cats are covered after the normal warranty expires. Something like 8 years or 80k miles. You need to find out why the cats failed.
DRAGUL is offline
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
09-24-2015 09:18 PM
Quick Reply: Bad cats on 07 v6
