Ignition key won't open door
Old 10-20-2014, 11:27 AM
ffury10
ffury10's Avatar
Default Ignition key won't open door
I recently purchased a 2006 Mustang. The Ignition key will not open the drivers door. It turns ok and seems to turn tumblers with full motion but it does not work. I have to open with wireless remote. I am worried that battery might die and then I'd be locked out. The drivers side inside lock switch does work.
The trunk had the same problem. I had easy access and pulled the cover and found a wire with a plug that was not connected. I reconnected it and the key started manually working again.
I don't want to pull the door panel if it's not necessary.
Any input into door lock operation would be appreciated.
ffury10 is offline
b8checker
09-30-2015 07:11 AM
09-25-2015 06:58 PM
Meystang
09-25-2015 04:05 PM
jessicarabbit
09-25-2015 12:41 PM
09-25-2015 09:06 AM
Quick Reply: Ignition key won't open door
