Fall is Here - Clean Your Cowl Drains
Old 03-12-2016, 09:27 AM
BrianK
BrianK's Avatar
Why would there be any more carbon monoxide in the cowl area than anywhere else. The exhaust is out the back. Unless there was an exhaust leak and you'd probably get that fixed.
Just another note on a rubber drain problem - and not to hijack the topic, but the same problem exists on fridges with lower freezers that get ice build up in the freezer. There is a rubber 'duckbill' drain accessible from the lower rear access panel that gets plugged with little things and causes water to back up into the freezer. The water is generated during the defrost cycle and is supposed to drain into a pan by the compressor. I pulled the rubber duckbill off, cleaned the ice buildup and no problems since. Same ****, Different Day LOL.
A good idea to take out the rubber cowl.
BrianK is offline
Old 03-12-2016, 10:28 AM
tradosaurus
tradosaurus's Avatar
Originally Posted by artsvettes73
The grommet is built to release water and stop carbon monoxide from entering the cabin. You may want to rethink your actions
Hmmmm...I suppose if there were a leak on the exhaust manifold. I never thought of that.
tradosaurus is offline
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
Scottyboy187
11-05-2015 04:18 PM
1987gt40ttopt
08-28-2015 10:49 PM
Quick Reply: Fall is Here - Clean Your Cowl Drains
