new wheels on my 88 but i need help with spacers
hey so i got some new wheels for my 88 theyre centerline forged 18" and i put them on and am noticing the back spacing is wrong i need to get spacer for it but im not sure what sizes i was thinking i would need 1" in the rear and .5" in the front but im not sure
here what it looks like
are you talking about the front wheels sticking out farther than the rears?
if so, mine looked like that too when i got my wheels. i put 1in spacers in the back and it made it look alot better.
just so you know, if you go with 1in spacers in the back, depending on your backspacing, you might have to roll the fender lip (i did).
You go anything more than 1/4", you should replace your studs with longer and stronger ones, IMO. I have 1/2" spacer and have done just that.
As for 88Mach1, you MUST have installed new lug bolts to go 1" and BTW, when you goin' 10's on that baby
Jazzy Kitty
no i actually have the spacers with the studs. like these...
haha! i don't think i am. i like the wheels i have now, and they don't make them in 10in, only 10.5in.
oh, and when did you become "Jazzy Kitty"? i like it.
Sorry Mach881, but I would NOT use those type of spacers
Correct me if I am wrong, but you would need to cut the stock bolts so they would not hit the back of the wheels as they must be over 1" long. Mine were about 1.5" long and the last 3/8" was un-threaded starter portion. You also have added strain on the stock lugs along with possiblity of lugs getting loose "behind" the wheel.
It is greater expense, but MUCH better to remove the stock studs and install upgraded longer ones. The Moroso studs I am using on my rear wheels (only ones with spacers, 1/2") are many times stronger than stock. I also had the advantage of a full 1" of threads into the lug-nuts for extra security.
To do this correctly, you may need to remove the axles and have them pressed in. I was able to avoid it, but was a PITA
Jazzer
yeah i know, i don't use them anymore. they were just a temporary solution until i could afford some wider tires.
oh and no i didn't have to cut the stock bolts. my wheels have a recessed area between the bolt holes that the excess bolts fit into.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
