New tire suggestions??
Ok, I have a 2000 mustang GT. My current tires (Nitto 275 DR's) are coming to the end of their life. I am having a lot of traction problems in first and second gear. At the local drag track I cannot keep my tires planted whatsoever (and yes, I am a decent driver). Launching the car at like 1500 RPM's I was able to pull off a 8.79 @ 82 MPH with limited spinning but any launch above that and I sit and spin. This is running them at about 20psi...
My question is what tires would you recommend? I NEED a decent lasting tire because it is a DD and also need decent wet traction (nothing superb). I have a 17x9" rim that I will be mounting them on. Should I try to run like a 305 nitto? Or would that be too wide for those rims? Would a BFG 275 be a good tire and have decent life? Any opinions would be appreciated.
Here is my mod list:
CAI
mac pro dumps
O/R x pipe
BBK LT's
Patriot Stage II heads
Crower stage II hi lift N/A cams
Full tubular suspension (too much to list), k-members etc.
aluminum driveshaft
Spec stage II clutch with lightweight flywheel
SCT flash tuner on 93 octane tune
and more.
Dyno'ed with stock rev limiter at 280whp and 310 ft/lbs.
With that in mind, make me some suggestions!
Chris
CAI
mac pro dumps
O/R x pipe
BBK LT's
aluminum driveshaft
and more.
Chris
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
