New Wheels
New Wheels
I have a 2007 GT with the stock 18" wheels.
I would like to know any pro's & con's of two different wheels, both will be 18 x 9 with 255 45 tires.
The difference is one has a 34mm offset with 6.3" backspace, the other has a 50mm offset with 6.81" backset.
You will actually probably not be able to install the 50mm up front. I think they will be too far inward. I hate using off-set measurements, can you measure the back-space of the current fronts and compare with proposed 50mm wheels? This will tell you if you have clearance.
The 34mm will fit without an issue, think you will have probs with 50mm set. Besides, the 34mm set will move the wheel about 5/8" outward of the 50mm set and fill the wheel well better, IMO.
Jazzer
Jazzer
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
