tires and wheels
Old 10-13-2010, 09:23 PM
tommyand teresa
tommyand teresa's Avatar
Default tires and wheels
I have a 2004 Mustang V-6 convertible that I purchased used. It came with 225/55/16. I want to purchase either a 17 inch Cobra or Bullett GT wheel. I have talked with 3 different dealers and have been 3 different answers on tires. They have told me a 245/45/17 ,255/55/17 , 205/55/17. I want to keep the same height as the tires now . Can you help me and let me know which is best or what I should get to go with the 17 inch wheels?
tommyand teresa is offline
Old 10-15-2010, 03:10 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I don't know what anyone was thinking saying ALL the following tires are the same diameter... assuming this is what happened:
225/55/16" tire = 25.7" diameter
245/45/17" tire = 25.7" diameter
255/55/17" tire = 28.3" diameter
205/55/17" tire = 25.2" diameter
You can run something other than the OEM diameter of 25.7" tire, but can vary a bit. You really need to make sure the front/rear tires are the same diameter to avoid ABS sensor issues. The common thinking is that 1" differential is the max to avoid such issues.
Jazzer
Jazzer The Cat is offline
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
mungodrums
09-28-2015 05:45 AM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
Quick Reply: tires and wheels
