Installing GT Fog lights
Old Aug 9, 2006 | 09:31 PM
XtacY's Avatar
XtacY
Default Installing GT Fog lights
I'm sure this is the bazillionth time this has been posted but I can't find the answer I'm looking for anywhere. My only question is to install GT fog lights on a sixxer, do I need a new bumper and grill?
Old Aug 9, 2006 | 09:50 PM
petepete's Avatar
petepete
Default RE: Installing GT Fog lights
yes
Old Aug 9, 2006 | 09:53 PM
StonedCrowe's Avatar
StonedCrowe
You can get the pony package, which comes with a new v6 grill (upper & lower), 2 fog lights, harness & new switch.
Old Aug 9, 2006 | 10:02 PM
dram57's Avatar
dram57
I bought the gt grill w/foglights on ebay for $150.
My detailer cut larger slits on the existing bumper slots and it fit with
some minor gaps at the bottom of the grill. From a distance can't see it.
I did not have to replace the upper or lower bumper.
SPARTAN VI's Avatar
SPARTAN VI
You don't need the GT bumper. You can muscle it into the V6 bumper. You will need the GT grille unless you plan on cutting out some holes on your V6 grille...
Old Aug 9, 2006 | 10:14 PM
XtacY's Avatar
XtacY
To my naked eye, I cannot notice one bit of difference between the V6 bumper/grill and the GT bumper/grill. What detail am I not noticing?
Old Aug 9, 2006 | 10:25 PM
SPARTAN VI's Avatar
SPARTAN VI
ORIGINAL: XtacY
I think there are extra tabs on the GT one that aren't on the V6 grille. The GT grille is also slightly larger than the V6 grille.
Old Aug 9, 2006 | 11:03 PM
dram57's Avatar
dram57
Spartan is dead right. The gt grill lower tabs do not align with the slots.
The curvature is definitely different. Hence, the slight gap at the bottom.
I had to remove the lower tabs.
Old Aug 10, 2006 | 01:17 AM
Tres Wright's Avatar
Tres Wright
Yes, +1 on the above comments. I put a GT grille in mine as well and while it did fit, it wasn't a perfect fit because the shape is different than the V6 opening. I suggest you consider a Street Scenes grille instead, you can get one that has lights in the same location as the GT grille or in the center of the grille ala Eleanor.
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
MustangHead91
Aug 23, 2015 09:37 PM
inyadreems
Aug 21, 2015 09:10 AM
dseg
Aug 8, 2015 09:00 PM
