how to? door moulding removal
I have a v6 with a full gt panel conversion [front/back bumper, grill, side rocker panels]. Ive removed the 'mustang' pinstripes now i want to remov these hideous door mouldings. any help? are th glued on? is it painted behind them? are there rivets?
RE: how to? door moulding removal
It's just glued on. Many guys on here have used fishing line going back and forth in a sawing fashion to get behind the molding. Once it's off, take WD-40 or Goo Gone to remove the adhesive. Make sure you clean the area afterwards and put on some wax.
I'm sure others will chime in with their experience.
I left the car out in the sun and used an ID card to pry an edge then just pulled it off. Most of it came off right away then i used a little adhesive remover to get the remainder. I hope ur cars not dirty because u will see the outline until u wash it. but on mine its a little darker where it was...
Going to pull these off soon
09-25-2015 06:58 PM
