Grill and Foglight question!!!
So this has probably been covered a hundred times but will a GT grill fit in a V6 stang, or do i have to buy an aftermarket grill with the fog light cutouts. Also if i get halo fogs, whats the easiest way to wire them so they turn on with headlights/highbeams? Thanks!
RE: Grill and Foglight question!!!
Generally the halo part of the fog comes on with the fog but you could wire it however you want
On the grille... some say you can force/cut to makethe GT grille fit. It all comes down to how fussy you are about the look/fit.
I went aftermarket (street scene), check the board vendors and ebay.... you'll find what you need including grilles with halo fogs.
(Use the search function in the main foruma quick google search on the subject pulled over 1000 links)
Look around the board this post is a couple down in the v6 forum
https://mustangforums.com/m_4184301/tm.htm
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
treesloth
09-28-2015 07:03 AM
