Lowering the Mustang 2006 GT
Now im new to all this tuning, mostly ride a Motorcycle, now the question is when I want to get my mustang lower so maybe only a 1-2cm. space bestween tire and the cover, how is that done, do i only need new springs and whats the best.
RE: Lowering the Mustang 2006 GT
I don't know if you will get it that low. The lowest kit lowers it 2 inches total. That's going to get it low but I don't know about the gap. It will be small though.
Eibach springs are the most popular. The Sportlines are the ones you want if you want it really low. The Pro-Kit is the one that is a little less aggressive at about 1.5 inches.
You will need a kit to correct the camber and castor. Either bolts for $30 or a better kit for about $190.
That's all you NEED, however I wouldn't stop there. Tokico D-Spec adjustable shocks ($500). and an adustable panhard bar to reposition the rear end in the proper place ($150) and upper and lower control arms ($200)...although I am no expert on those so you might ask around.
I suggest doing a search on the site for this, as it has been discussed many times.
I have the Eibach Pro-Kit springs which lower the car about 1.5 inches. I also had new billett LCA's installed, but the shocks are still stock and I don't have a camber plate/bolt. It rides and handles fine for dailystreet driving.
[IMG]local://upfiles/84814/0F03593225604136B70E35F34A197064.jpg[/IMG]
[IMG]local://upfiles/84814/A9D6038ABB684E76A0EF9AB886C357D2.jpg[/IMG]
I lowered mine 1.5" with Ford racing.Went all out,springs,struts,shocks,sway bars,front and back.Handles sick,but a real stiff ride.Need to correct neg.tow in of front tires.
[IMG]local://upfiles/91531/632DC27AF2B1484BA7C3D29F05026FE6.jpg[/IMG]
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
