HID installation question
Old Aug 8, 2008 | 01:22 PM
ixmotoxi's Avatar
ixmotoxi
Default HID installation question
Hey guys,
Yeah I'm new but had a couple questions that you could hopefully help me out with. Just got my HID kit from retro solutions and getting ready to install it.
First off, did you guys use 3m tape (available @ local car shop?) to mount the ballasts or did you use some sort of bracket vs. drilling into the frame.
Second, I know that the kit has to be powered by the battery but i noticed that in the kid there's only a wire for the positive connection of the battery?
Lastly, I've figured out where everything hooks up to but am having difficulties finding the headlight wire harness. Where exactly is it?
Thanks for the help in advance b/c I need it. haha
Old Aug 8, 2008 | 05:36 PM
jahudso2's Avatar
jahudso2
Default RE: HID installation question
My kit off of ebay came with 3m doublesided tape in the box (it looks like two sticky note pads). The positive terminal is the only one you hook up to. The harness should have multiple other extra rings hanging off of it at random points that need to be grounded. Just find the nearest screw and remove it then place the ring under the screw to ground it. The headlight signal comes from your stock headlight wiring harness (the one that plugs right into the back of your stock headlight bulbs.) Hope this helps. ask more questions if needed.
Old Aug 8, 2008 | 06:10 PM
ixmotoxi's Avatar
ixmotoxi
thanks, it helped. I just really wanted to confirm those questions before I got started. I'll give it a go after work. thanks again.
Old Aug 8, 2008 | 07:00 PM
jahudso2's Avatar
jahudso2
No problem. if you get stuck again, just ask. I had two problems when i installed my kit. First the plugs that go onto the balasts plugged on either way on my kit, and i had the polarity switched on them since there was no indication on how the clip went on. Then i found out that my bixenon function was reversed. It turned out they send me a defective set of bulbs that were mounted upside down in the plastic housing, so I ended up sending them back. I'm planning on getting a 5000K bixenon set from Retro after I get my car inspected this fall.
Old Aug 15, 2008 | 03:16 PM
retrosolutions2's Avatar
retrosolutions2
Former Sponsor
We owe all parties here an explanation...
Due to consistent membership and forum function issues here with mustangforums.com we have no choice but to cancel our agreements with the owning party, Internet Brands Inc. For the pat few days, putting all other issues aside, our account has been banned without provocation, without merit, withour explanation, and all we have received is a "we'll look into it" with no response.
We feel very bad that we can no longer directly support a loyal and supporting community, but our hands are very much tied in the issue. We basically paid for a product/service that we never received.
If you require any assistance please contact us directly at sales@retro-solutions.com in the future
Diode Dynamics
28
May 26, 2022 12:02 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
inyadreems
Aug 21, 2015 09:10 AM
