pony corral grilll insert for gt?
Old 01-06-2009, 06:25 PM
  #21
ckone0814
ckone0814's Avatar
300GT - nice car. the retro touches are great. i see you're sorta in my neighborhood.
ckone0814 is offline
Old 01-06-2009, 08:33 PM
  #22
ziperhead
ziperhead's Avatar
Try here
http://www.scottdrake.net/prodgrp_li...%26+Components
ziperhead is offline
Old 08-21-2011, 09:25 PM
  #23
edcologne
edcologne's Avatar
Originally Posted by BeeStang
It's real simple... I bought just the chrome trim piece (don't know the part number, sorry) and then cut off the round fog openings with a hack saw. Once they are removed I placed the trim around the pony and marked where they touched the fog bezel inside edge (I used a peice of masking tape to mark the cut off, I left just a hair for adjustment), then cut of the little pieces of the trim bar and took some sand paper and sanded and dry fitted until it was snug and perfect. Once it was fitted, I went and bought a couple of stainless sheet metal screws and some fender washers (big and round with a small hole) and srcrewed the trim snug from behind using the washers to hold it to the OEM grill (the black grill needs to come off in order to screw it all together). I also painted the washers flat black to match the grill so thay can't be seen. The trim has sort of a v-shaped notch in it (from behind) and the screw will set into it once you start the screw. Just be careful that you don't over tighten the screw and crack the chrome trim. The trim is very light weight and won't take much to hold it in place. Once you get the trim you'll understand what I'm talking about. Also, I would wait until you get the trim so you can see what size screw to use and how long it needs to be once you fit the modified trim to the OEM grill. Again, it will take a little observation to figure it out. I went with just 2 screws, some may want to use 4.
I had the Web electric one and it used some weird fasting system that I thought was odd and wasn't very firm (mine wiggled a little when I installed it on my white 06 coupe. Anyway, PM me if you have any specific questions.
very helpful write up
sure, in a perfect world i'd change to the whole pony grill, but since it doesn't fit w major modifications, changes thats just the best i can do to accent the 67/68 look i liked the car for in the first place.
did it pretty much as described. got a used, slightly damaged pp grill off ebay, took off the chrome (plastik) insert and went to town w it.
only used different screw setup. didn't want to take off grill. got 4 long threaded brass screws, cut off head, cut thread in plastic groove of trim, reinforced w epoxy, put fender washers and nuts behind grill (got my phat fingers in there just enough), secured w locktite threadlock. love it.
didn't go for the big light rings, not my cup of tea.
edcologne is offline
Old 09-28-2011, 02:06 PM
  #24
edcologne
edcologne's Avatar
there it is
Old 01-13-2012, 05:06 PM
  #25
edcologne
edcologne's Avatar
trying out my picture embedding capabilities
Old 01-14-2012, 03:34 PM
  #26
07 Stang
07 Stang's Avatar
It's was one of the main reasons I wanted the Pony Package.
07 Stang is offline
Old 04-21-2012, 07:54 PM
  #27
edcologne
edcologne's Avatar
noticed this
http://www.ebay.com/itm/2008-Ford-Mu...fdad30&vxp=mtr
just in case someone was considering what i did.
Old 04-21-2012, 08:22 PM
  #28
05MineralGrayV6
05MineralGrayV6's Avatar
nice work Ed
05MineralGrayV6 is offline
Old 04-22-2012, 09:05 PM
  #29
BAB GT
BAB GT's Avatar
Perfect solution! I had an '06 V6 with the pony package and loved the grille, so now I can give my '06 GT the same look.
BAB GT is offline
Old 08-27-2016, 04:46 PM
  #30
edcologne
edcologne's Avatar
second time around...
baddog671
07-26-2016 01:20 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Thunderball
15
11-22-2015 11:49 PM
Florida Regional Chapter
09-30-2015 08:04 PM
09-16-2015 07:53 PM
Quick Reply: pony corral grilll insert for gt?
