pony pac fog lights
Relay Method:
Find Connector C2280C on the back of the SJB.
C2280C is the third big connector down from the top
Find the DarkBlue/White wire on C2280C on the SJB.
You will want to ground this wire when you want the
fog lights to be on.
Find Connector C2280A on front of the SJB.
C2280A is the biggest connector on the front of the SJB.
Find the Red/Yellow wire on C2280A on the SJB.
This is the 12V Ignition Switched power source.
Or use the Black/Pink wire on C2280A.
This is the ACC DELAY circuit for fogs when its active also.
Purchase a general purpose fog light relay.
Ground one side of the coil and the Common
terminal of the contacts. Ground is the Black wire on C2280A.
Hook the Normally Open contact terminal to the
DarkBlue/White wire.
Then hook the other side of the coil to 12V switched
source of your liking on C2280A.
FOG LIGHT WIRING DIAGRAM
Or you could remove the headlight switch, pop it apart (three tabs)
and break off the plastic ward that makes you push the fog light
switch in before you can turn off the headlight/clearance lights.
Just pull it out and no clearance lights, just pony fogs.
