removing rear gt badge
Old 05-07-2009, 10:18 PM
sweetlou69
sweetlou69's Avatar
Default removing rear gt badge
i was wondering the best way of removing the rear gt badge on the trunk lid?
sweetlou69 is offline
Old 05-07-2009, 10:29 PM
Doogie65
Doogie65's Avatar
Fishing line worked like a charm for mine. Then some good adhesive remover and maybe a plastic scrapper for the remaining glue.
Doogie65 is offline
Old 05-07-2009, 11:16 PM
sweetlou69
sweetlou69's Avatar
fishing line huh? im trying to visualize how that would work. i guess ill figure it out next time i look at the the thing lol
Old 05-08-2009, 02:19 AM
rettgoings
rettgoings's Avatar
slide the fishing line in between the badge and the car...pull down...have you cut clay? like flossing. and the remaining 3m can be rolled off and cleaned with a bunch of stuff
rettgoings is offline
Old 05-08-2009, 02:55 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Stuff like goo gone or alcohol
mygt500 is offline
Old 05-08-2009, 06:47 AM
ddiehl
ddiehl's Avatar
I used the fishing line also. Just roll the ends around your hands and work it back and forth between the deck plate and the car and "saw" down. I used a light coat of lacquer thinner to get the glue off. Then cleaned it good to get the thinner residue off.
ddiehl is offline
Old 05-09-2009, 07:29 PM
WYO07GT
WYO07GT's Avatar
So I take it there are no pins through the lid? For some reason I thought there was.
WYO07GT is offline
Old 05-09-2009, 09:41 PM
05 Mustang
05 Mustang's Avatar
there are 2 alignment pins on the backside of the GT rear badge, near the center, that go into back of the trunk. you just have to use the fishing line and come in from all 4 sides towards the center, cutting the adhesive enough to pull it loose from the trunk
05 Mustang is offline
Old 05-10-2009, 10:11 PM
WYO07GT
WYO07GT's Avatar
Thats what I thought. I almost got excited for a minute about being able to take it off and not need to fill holes. I know there are the magnetic black out panels like rettgoings, but i'm just not sure abou them yet. It would be nice to live where I can actually see these things on a car once in a while instead of past bufu where finding a modded stang is like finding a needle in a haystack.
WYO07GT is offline
Old 05-11-2009, 05:58 AM
Daniel60
Daniel60's Avatar
Hell , I pulled my off.
Daniel60 is offline
Quick Reply: removing rear gt badge
