retractable antenna
Old Sep 4, 2009 | 03:21 PM
  #21
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by conor1148
i see, where is the ground for the stock radio located at?
i would check my shop manual if it would finally get here *grumble grumble*
Shop Manual Online :)
Originally Posted by i8acobra
I wasn't even thinking about that. However, the Mustang Shaker 500 and 1000 both have external amps, I believe. So, there should be a remote turn-on wire from the deck to the amp. You'll have to figure out which one it is and tap into that one for the antenna turn-on lead.
The shakkkker puts out 5V for the amp turn on.
Incompatable with the antennas 12V coil relay....
Old Sep 4, 2009 | 03:45 PM
  #22
conor1148's Avatar
conor1148
Originally Posted by Centurion96
When I went through the process of checking availability for my 07 vert., it said the Metra PW22 would not fit my car. I just mention this so that you are forewarned.
BB
Semper Fi
do you mean it wont fit as in it wont work electric wise? or wont fit inside the fender?
also, 157db, you are the MAN!
Old Sep 5, 2009 | 08:35 AM
  #23
157dB's Avatar
157dB
Cut & Paste Expert
Ford Printed WorkShop Manuals ROCK....
Old Sep 6, 2009 | 07:06 PM
  #24
Sleeper05's Avatar
Sleeper05
Get a window-mounted powered antenna!
Old Sep 6, 2009 | 08:21 PM
  #25
conor1148's Avatar
conor1148
that's probably what i will end up doing until i get a head unit that can do the up/down on the antenna, a retractable antenna would have been so cool though.
Old Sep 7, 2009 | 02:13 PM
  #26
xxdmxx's Avatar
xxdmxx
I got a window mounted antenna and you can't see it unless you look from under.
Old Sep 8, 2009 | 08:38 AM
  #27
eastcoastoutlaw's Avatar
eastcoastoutlaw
I'm thinking about it
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
movielover40
Sep 15, 2015 10:37 AM
cbird1177711
Sep 3, 2015 08:43 PM
