What's the best way to remove the antenna ball?
Old Oct 30, 2009 | 08:33 AM
Murphdog's Avatar
Murphdog
Default What's the best way to remove the antenna ball?
After going through 2 shorty antenna's that broke, I've decided to mod one of the 2 stock antenna's I have. After trying to pry it off with some pliers and not being successfull, what are my options? I can tell I will definately have to spray paint it black when I'm done.
Old Oct 30, 2009 | 09:02 AM
StangMan001's Avatar
StangMan001
I put the antenna in a vice...length wise. I put the ball end of the antenna in the claw end of a hammer. Then proceeded to hit the hammer...with the antenna, with another hammer till the ball popped off. Hope this helps.
Old Oct 30, 2009 | 09:04 AM
Doogie65's Avatar
Doogie65
Google is your friend...
I used this procedure and it work great! The key is to put some tape over the ball as could be tough to locate once it comes loose.
http://www.mustangworld.com/ourpics/fcar/antenna1.htm
Old Oct 30, 2009 | 09:21 AM
jwog666's Avatar
jwog666
i used a vise grip and pulled it off with a twist. after i put it on the shortened antenna i touched up the ball with some black paint.
Old Oct 30, 2009 | 01:20 PM
Nuke's Avatar
Nuke
I had little patience on both my stock and the g/f's stock antennas and ended up scoring the ***** so badly that I simply tossed 1 in the trash and kept the other "just in case", then found shorties on ebay for about $15.
Old Oct 31, 2009 | 02:42 AM
IndecisiveS197's Avatar
IndecisiveS197
after I chopped my antenna, I stuck the top part in a vice and then with a pair of pliers (wrapped the ball with a cloth first) I just yanked it off.
Putting it on was an easy affair as well. I used a grinder and ground off a bit so the ball could slip on, and then gave it a few good whacks with a hammer. No superglue necessary.
by far the easiest mod I've ever done. my gf said..."give me 15 minutes, I'm running late" and in that time I was able to not only do the mod, but also do a quick paint. Having a grinder definitely helps speed up the process tho.
Old Oct 31, 2009 | 12:46 PM
millpond's Avatar
millpond
Did mine last night (the aftermarket 14" antenna got bent somehow). Was an easy mod...used a bolt cutter to shorten the antenna.
Old Oct 31, 2009 | 01:00 PM
Murphdog's Avatar
Murphdog
yeah the first thing i did was cut the antenna in half, will probably do the ball today. Thanks for the suggestions.
Old Oct 31, 2009 | 01:07 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I'm glad no one said they'd put a ball in a vise... that would be a painful vice.
Old Oct 31, 2009 | 01:20 PM
tampa07gt's Avatar
tampa07gt
I'd use my hacksaw.
