Install Question
Old Nov 2, 2010 | 11:04 PM
Noodle23's Avatar
Noodle23
Default Install Question
SO in relation to my other thread, how easy is it or hard is it to install a new hood? I know the simple answer of with the right tool but i mean really how hard is it.
thanks
Old Nov 3, 2010 | 06:29 AM
2005Redfire6's Avatar
2005Redfire6
Not much too it but a few bolts... I've taken mine off but never replaced. Its the same concept.
Old Nov 3, 2010 | 06:55 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Experience taught me to put a blanket across the engine bay and the top of the fenders.
You won't scratch said fenders upon removal/reinstall and if you drop a bolt, you won't loose it in the bay.
Old Nov 3, 2010 | 12:56 PM
Fifthwind's Avatar
Fifthwind
Good advice above.
*It's pretty straight forward. put it on and minor alignment adjustments.
Old Nov 3, 2010 | 07:26 PM
09cs's Avatar
09cs
It's 2 bolts to get the actual hood off I believe
Old Nov 3, 2010 | 07:32 PM
Menes's GT's Avatar
Menes's GT
2 bolts on each side of the hood, detach the window sprayers,
if your doing this by your self use the hood prop to hold the hood up as you unbolt the hood. hope that helps
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
whatsup62
Aug 29, 2015 01:25 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
