Quarter Window Louvers - 3m tape question
Old Apr 22, 2011 | 07:55 AM
kevinmalec's Avatar
kevinmalec
Thanks 808 Muscle!
Stealth GT, I used the adhesive promoter packs and the alcohol packs that came with the kit. It was a bit warm and muggy in the garage and the 3M tape stuck very well!
Old May 11, 2011 | 09:54 PM
S197winstang's Avatar
S197winstang
I am on my 3rd attempt with the passenger side. Did everything mentioned yet it comes off--ny other suggestions?
Old May 12, 2011 | 08:45 AM
kevinmalec's Avatar
kevinmalec
The front corner on my driver's side ended up not sticick to my car, so I had to remove the 3M tape off of the louver by using fishing line and then used sand paper to get the rest off. I bought Super Duty 3M double sided tape from Home Depot ($15) and I also bought 91% rubbing alcohol from Walmart to rub down the car, where the louver stick. Hence, you must use 90% alcohol or higher in order for it to work. Once you do this, you should be fine!
Old May 12, 2011 | 08:53 AM
Franchi's Avatar
Franchi
After about 2 years, check it periodically. I have the same AM ones and getting on the freeway last week, noticed in my rear view mirror that my left louver was starting to flap slightly. I pulled over and pulled it off pretty easily. My right one was still on rock solid but I took both off as Im going to clean the area and reapply them.
I installed them about 2.5 years ago so they did last a long time.
Old May 12, 2011 | 09:11 AM
kevinmalec's Avatar
kevinmalec
Appreciate the info! I'll be sure to check the louvers periodically to ensure they are sticking.
I've heard it's a real pain getting the 3M tape off of the louvers. It took me over two hours to fix the corner and was a pain due to the lack of space I had between the louver and the car. Let me know how it goes!
94z
Oct 11, 2004 02:22 PM
xtrm1stang
Sep 17, 2004 07:46 AM
94Cobra31
Aug 20, 2004 10:26 PM
94Cobra31
North East
Aug 16, 2004 08:28 PM
94Cobra31
Aug 16, 2004 08:25 PM
