repainting faux gas cap
Old 07-27-2012, 02:22 PM
tigercrazy718
tigercrazy718's Avatar
Default repainting faux gas cap
so after 2 years the black spray paint is finally chipping on my faux gas cap, so its time to repaint it. i cant remember what grit sandpaper i used last time, so i wanted some suggestions on which grit to use, or does it really even matter? thanks!
tigercrazy718 is offline
Old 07-27-2012, 02:57 PM
BleedinBlue
BleedinBlue's Avatar
It doesn't really matter. It's common sense really...don't go so coarse that it leaves deep striations that are hard to sand out, and before you prime finish with very fine paper. Plan on using 3 or more different grits.
BleedinBlue is offline
Old 07-27-2012, 03:27 PM
tigercrazy718
ok cool. never really sanded anything painted before so im flying blind lol. anyone have any suggestions for priming the plastic on the gas caps?
Old 07-27-2012, 05:12 PM
BleedinBlue
Did you use adhesion promoter the first time? I'd sand it really well, spray a coat or two of adhesion promoter, then a couple light coats of any primer, let it COMPLETELY dry (Maybe a full day), give it a very light wet sand, then paint with several very light coats.
If you gloss it, put a couple coats of clear on it also. I'm not too sure about clear if you are painting it flat black, I'd guess there is a flat clear coat, but I'll let someone else chime in on that.
Old 07-27-2012, 05:20 PM
tigercrazy718
i believe last time i used an adhesion promoter, but it was 2 years ago and i was going by a friends guidance lol. i def put some clear on i think tho because it was def shiny, but still looked like it had some texture like matte does, so i guess its kind of like a semi gloss look
Old 07-27-2012, 08:39 PM
gothamems
gothamems's Avatar
Plastidip it! Down the road you won't have to worry about chips!
gothamems is offline
Old 07-29-2012, 02:57 PM
2005Redfire6
2005Redfire6's Avatar
+1 thats what I would do...
2005Redfire6 is offline
Old 07-29-2012, 04:23 PM
BleedinBlue
I would never recommend plasti-dip, except for this. They're right...it would be much easier, and apparently if you screw up that crap just peels right off. If in a year or two, or a few months it starts peeling, it's a super easy fix. I've never used the stuff so I didn't even consider it for this.
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: repainting faux gas cap
