New Nitrous System
Old Mar 10, 2006 | 07:08 PM
zanemoseley's Avatar
zanemoseley
Default RE: New Nitrous System
So what is the deal on top of the plenum in this picture. I found it at Summit Racing.
http://store.summitracing.com/defaul...=egnsearch.asp
Old Mar 10, 2006 | 09:29 PM
F00Mustang's Avatar
F00Mustang
The kit you found, even though it says it will fit the new mustang, is for the 99-04 4.6 (notice the direction that the throttle body is facing). That kit will not work on the 3v 4.6.
Old Mar 10, 2006 | 11:47 PM
V8 Aggie's Avatar
V8 Aggie
when you have a nitrous kit that taps into the fuel rail that is a "wet" system correct?
So if you are looking into staying under warranty the easiest way, wouldn't I want to go with a dry kit so that it can be taken off incase I had any engine problems?
Which one is safer for our cars? wet or dry?
thanks
Old Mar 11, 2006 | 09:35 AM
F00Mustang's Avatar
F00Mustang
Actually the ZEX and NOS wet kits just use a spacer on the sensor in the front of the fuel rail to get fuel. This spacer can easily be removed with two bolts and put back to stock.
Old Mar 11, 2006 | 10:23 AM
sublimaze's Avatar
sublimaze
ORIGINAL: zanemoseley
It sounds like for the average daily driver that likes to whip *** sometimes the nitrous may be better than a charger since the engine isn't always boosted.
not always true. a centrifugal blower adds boost progressively, begining around 2000-2500 rpm and reaching full boost at redline. below 2000 rpm there is virtually no boost, so the engine isn't "always boosted"
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
