Dynamat
Old Mar 28, 2006 | 05:14 AM
nickd06's Avatar
nickd06
Default Dynamat
How much would it be to do the trunk and the doors? What else could/would you have covered in dynamat?
Old Mar 28, 2006 | 08:34 AM
Philostang's Avatar
Philostang
Default RE: Dynamat
Hey Nickd,
Sound deadeners can be used on the entire interior--trunk, doors, inner fenders, floors (trunk and passanger compartment), roof, c-pillar, etc. It really depends on how whole-hog you want to go. I'd say (but others, please chime in), in order of importance, a.) immediate area around speakers, b.) floors (pass.compartment, then trunk), c.) underside of trunk, d.) side panels, e.) roof.
I posted this link in the 4.0 section in the thread "DYNAMAT ALTERNATIVE" so you might want to run through that thread--I think they discuss how much they use.
Read up on some research Don Sambrook did with sound deadeners. He has an excellent site that will help put you in a position to make an informed decision. Check out:
http://www.sounddeadenershowdown.com/
Best,
-j
Old Mar 28, 2006 | 09:17 AM
MikeVistaBlue06's Avatar
MikeVistaBlue06
I ♥ Acer
Default RE: Dynamat
I just finished putting 48 sq. ft. of Damplifer Pro into my car. I read the same article listed above. It works great and is less expensive than Dynamat or Dynamat Xtreme.
https://mustangforums.com/m_1173323/tm.htm
Check them out at: http://www.secondskinaudio.com/cgi-bin/index.cgi?_scb=1
Mike
Old Mar 28, 2006 | 02:20 PM
MJDGator's Avatar
MJDGator
Default RE: Dynamat
Check out RAAMaudio Their RAAMmat is supposed to be just as good quality wise as Dynamat xTreme but cheaper.
Rick there posts a bit on a Subaru board that I go on every once in a while. If you shoot him an email letting him know what kind of car you have he will help you out. It seems he has done quite a bit of sound deadening. You really need to use the foam sheeting (Ensolite) along with mat material (Dynamat, RAAMmat, etc) to get good sound deadening. Everyone that has posted about RAAMmat seems pleased with the product and Rick's suggestions.
Old Mar 28, 2006 | 02:48 PM
nbk13nw's Avatar
nbk13nw
Default RE: Dynamat
Probably around 30sqft to finish off the trunk area. 6 to 8 for each door. I would cover the entire trunk area, the rear shelf (I coverd both top and bottom. The doors after pulling the plastic sheeting off as well as the inside of the exterior door panel. Inside fender wells, tranny tunnel and floor if possible. Real hardcore? The the roof liner and whatever plastic panels can be gotten too to keep the rattle down.
ORIGINAL: nickd06
69FB
Aug 18, 2015 08:50 PM
nicarc369
Jul 19, 2011 04:52 PM
06stangGT
Aug 6, 2007 01:09 PM
richmod
May 3, 2007 12:01 AM
Azure
15
Jan 24, 2007 12:46 AM
