Sponsored by:
Sponsored by:
What oil pan and windage tray work with 05/06?
Old 04-01-2006, 12:29 AM
chevykiller
I ♥ Acer
chevykiller's Avatar
Default What oil pan and windage tray work with 05/06?
Okay, so I'm getting the canton windage tray (see link) and I also would like to have a 9 quart pan to go with it. I could only find the moroso aluminum 7 quart oil pan but it is listed as only being compatible with up to 04 models. Does anyone know if this oil pan will work with our cars and if there is a 9 quart pan available anywhere for our cars. All help is gretly appreciated.[sm=feedback.gif]
Mark
http://www.rpmoutlet.com/03cobramotor.htm
chevykiller is offline
Old 04-01-2006, 01:03 AM
chevykiller
I ♥ Acer
Default RE: What oil pan and windage tray work with 05/06?
Someone has to know something...spyder?...professor wizard? Hawgman? Help....
Old 04-01-2006, 01:32 AM
rattsj
rattsj's Avatar
4.6 modular should work fine check out http://www.livermoreperformance.com/ford_oil_pans.html
I would just contact these guys before placing your order.
rattsj is offline
Old 04-01-2006, 01:39 AM
rattsj
rattsj's Avatar
Then again I know you swapped engines but if I remember correctly you went with the same thing besides the top.
Still waiting on my block from Bennett its driving me crazy. Sent the crank and goodies almost 3 months ago. I got a Kenne Bell here sitting in a freakin box ahhhhhhhhhhhhhhhhhh
rattsj is offline
Old 04-01-2006, 01:48 AM
Tik_Tok
Tik_Tok's Avatar
" 15 to 18 Hp at 6000 RPM"
That's pretty impressive for $70! Has anyone tried one yet? Or is it like a 'Turbonator' type product?
Tik_Tok is offline
Old 04-01-2006, 01:57 AM
spyder7724
spyder7724's Avatar
mark i think the oil pans are the same on all models except trucks. 5.4/4.6 will interchange. i also bought that windage tray from rpm outlet but i didn't use it. i wasn't aware that there was one on from the factory until i pulled the pan and saw it. i just kept it since i'll have another shortblock to build this winter. have you called hamburgers pans,milodon, stef's or canton? also i think the guys name is jeff johnston(billetfab.com), i see his add in national dragster all the time. he has some really trick stuff. my dad has a guy that makes his pans from scratch with billet rails and whatever dimensions you want. i'll call him in the a.m. and try to get his #. he hasn't had to order a pan in a while so hopefully he is still in business.
spyder7724 is offline
Old 04-01-2006, 02:06 PM
chevykiller
I ♥ Acer
ORIGINAL: spyder7724
Thanks - I haven't pulled the motor yet so I didn't know. I thought ford only used one with their Cobra R. Is it the canton that's in there now? This is the one ford used for the corbra R? If it is, then I only need the larger 9 qt pan.
Mark
Old 04-01-2006, 03:35 PM
lostsoul
lostsoul's Avatar
I need one to since I had "parts" fly though it =-/ .. maybe I can get one at mmr too.. haha..
lostsoul is offline
Old 04-01-2006, 03:38 PM
chevykiller
I ♥ Acer
ORIGINAL: lostsoul
lol... Does anyone know if our stock oil pans are 5 quarts?? I think they are but I'm not sure. I want to go 9 quarts but I can only find 7 so far....
soulcaliber39
12-28-2016 04:57 AM
67LimeCoupe
11-25-2015 08:55 PM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: What oil pan and windage tray work with 05/06?
