What oil pan and windage tray work with 05/06?
Okay, so I'm getting the canton windage tray (see link) and I also would like to have a 9 quart pan to go with it. I could only find the moroso aluminum 7 quart oil pan but it is listed as only being compatible with up to 04 models. Does anyone know if this oil pan will work with our cars and if there is a 9 quart pan available anywhere for our cars. All help is gretly appreciated.[sm=feedback.gif]
Mark
http://www.rpmoutlet.com/03cobramotor.htm
Mark
RE: What oil pan and windage tray work with 05/06?
4.6 modular should work fine check out http://www.livermoreperformance.com/ford_oil_pans.html
I would just contact these guys before placing your order.
Then again I know you swapped engines but if I remember correctly you went with the same thing besides the top.
Still waiting on my block from Bennett its driving me crazy. Sent the crank and goodies almost 3 months ago. I got a Kenne Bell here sitting in a freakin box ahhhhhhhhhhhhhhhhhh
mark i think the oil pans are the same on all models except trucks. 5.4/4.6 will interchange. i also bought that windage tray from rpm outlet but i didn't use it. i wasn't aware that there was one on from the factory until i pulled the pan and saw it. i just kept it since i'll have another shortblock to build this winter. have you called hamburgers pans,milodon, stef's or canton? also i think the guys name is jeff johnston(billetfab.com), i see his add in national dragster all the time. he has some really trick stuff. my dad has a guy that makes his pans from scratch with billet rails and whatever dimensions you want. i'll call him in the a.m. and try to get his #. he hasn't had to order a pan in a while so hopefully he is still in business.
ORIGINAL: spyder7724
Mark
ORIGINAL: lostsoul
I need one to since I had "parts" fly though it =-/ .. maybe I can get one at mmr too.. haha..
soulcaliber39
12-28-2016 04:57 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
