CAI Causing Check Engine Light *Update*
Old Sep 27, 2006 | 11:00 PM
  #21
06GT4RAD's Avatar
06GT4RAD
Default RE: CAI Causing Check Engine Light
ORIGINAL: stargazer468
Is driving with the CEL (lean conditions) for short periods of time really bad?
Yes it can in fact be catastrophic.
Richard
Old Sep 27, 2006 | 11:26 PM
  #22
stargazer468's Avatar
stargazer468
thats what i figured, good news is i got my SCT2 to work and now the V6 makes me much happier can you say spin first chirp 2nd and 3rd? not bad for a 6er
Old Sep 28, 2006 | 12:11 AM
  #23
undecided.steve's Avatar
undecided.steve
Good show!
I'm curious, what specifically was wrong and how did you fix it?
Tia!
Steve
Old Sep 28, 2006 | 10:08 AM
  #24
Daniel60's Avatar
Daniel60
ORIGINAL: Sonic Boom NH
A lean condition at any time, even for a short time, is bad for the motor. A lean condition means much higher temperatures in the combustion chamber then normal and that is not good for the values, cylinders, rings etc…
Higher then normal combustion temperatures can also cause pre-ignition (knock) that is VERY bad for the rods and crank. If the knock is not bad enough then generally the computer can correct for that by taking timing out which takes horsepower away. However the computer can only correct or compensate so much for a problem…
Does a lean tune cause pinging? or how would you know? If you never have a check engine light I assume everything is 10-4/
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
