disconnected plug under the midconsole?
Old May 7, 2006 | 01:02 PM
sl8anic's Avatar
sl8anic
Default disconnected plug under the midconsole?
Anyone have any idea what the disconnected plug under the trim of the under-arm/cup-holder compartment is? It's connected to a "t" wiring holder that's also attached to the +12V jack located in the under-arm compartment.
AD
[IMG]local://upfiles/26821/0374A7CF2B6D440FAC7953570A1D750E.jpg[/IMG]
Old May 7, 2006 | 03:21 PM
rex7010's Avatar
rex7010
Default RE: disconnected plug under the midconsole?
If I was to guess ( and that is what it is.. a guess ) I would think for some kind of accessory.. maybe if you installed a cig. lighter..???
Rex
Old May 7, 2006 | 09:35 PM
sl8anic's Avatar
sl8anic
Well, it can't be that as there are 5-6 wires of a fairly small gauge in the connector... Also, the cig lighter/power outlet is already connected (the green wire in the pic).
Pin #5 (or what is marked as #5) on that connector is a switched +12V DC, in case anyone was curious.
AD
AD
ORIGINAL: rex7010
Rex
Old May 7, 2006 | 11:24 PM
afixer's Avatar
afixer
i just looked it up there should be three connectors under the console. 1 power plug 1 paking break and 1 for the shifter(auto) looks like you have a stick ? if thats it it is for if you have an auto. od on off light for shifter and pos switch. hope this helps
Old May 7, 2006 | 11:28 PM
sl8anic's Avatar
sl8anic
Right on, I do have a standard. Thanks man! Now on to find that pesky dimmer control wire on the stereo...
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
