2005 cd player/radio removing/replacement
Old May 9, 2006 | 12:51 AM
lykingit's Avatar
lykingit
Default 2005 cd player/radio removing/replacement
Have a 2005 mustang with a single disc player that I'd like to change out for a 6 stack unit like I had in an 03 GT. Found a few, but I'm not sure of a correct fit. By the way, how do I remove the bezel/frame from around the radio.
Old Feb 13, 2007 | 09:46 AM
alecsm's Avatar
alecsm
Default RE: 2005 cd player/radio removing/replacement
i'm also intrested about that ....but i didn't findit on search
Old Feb 13, 2007 | 11:44 AM
alecsm's Avatar
alecsm
how can i remove my shaker 500 unit ???? I'd like to removeit ! Thank's
Old Feb 13, 2007 | 12:04 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
You'll have to have it programmed for the illumination to work properly when changing factory to factory head units. To take it out the side trim panels that run up alang the radio from the carpet up are clipped in. just pull them straight back and then you can access to the screwa that hold in the radio.
Old Feb 13, 2007 | 04:21 PM
howarmat's Avatar
howarmat
s197 Junkie
The shaker 500 is a 6-disc player. Why change to a different unit? If you want to get a better head unit I can understand that, I went with a Z1. But I would not worry about finding a 6 disc changer in the HU, I would stick with a Shaker 500 for that feature. You can upgrade for about 150-170 and it will fit perfectly
It does not need reprogrammed, you just have to feed a wire from the headlight switch the the illumination line on the head unit.
Old Feb 13, 2007 | 04:33 PM
PROMETHEUS PRIME
I work at a dealer so it was easy for me to reprogram when I put in the 6 then it was to add a wire.
Old Feb 13, 2007 | 05:01 PM
alecsm's Avatar
alecsm
ORIGINAL: PROMETHEUS PRIME
10 x thank's
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mdj89
Oct 26, 2015 11:53 AM
mdj89
Oct 8, 2015 09:16 PM
bconboy
Sep 24, 2015 01:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
