Chipped Paint
Old Jun 3, 2006 | 03:00 PM
mikefan20's Avatar
mikefan20
Default Chipped Paint
The problem with driving fast is I'm getting chips and dings in the paint on my hood. What are people using to repair their paint?
Old Jun 3, 2006 | 03:03 PM
Fizzie06's Avatar
Fizzie06
Default RE: Chipped Paint
touch up paint from the dealership
Old Jun 3, 2006 | 03:43 PM
GM Supercar's Avatar
GM Supercar
I always try to keepa good distance from people in front of me too.
Old Jun 3, 2006 | 05:07 PM
hottymustang's Avatar
hottymustang
ORIGINAL: Fizzie06
+1
Old Jun 3, 2006 | 06:46 PM
Daniel60's Avatar
Daniel60
color cure wax by turtle wax. In comes in different colors. If you use touch up on small chips it will look worse then before.
http://www.turtlewax.com/products/pages/colorcure1.htm
Old Jun 3, 2006 | 07:15 PM
Fizzie06's Avatar
Fizzie06
Unless you suck at applying it...........it won't I had on and you honeslty can't tell where it was. Listen don't get a pink bottle of touch up if you car is blue. It also depends on where the chipped paint is. You theory on touch up paint is most deffinatly not true. You must of had a bad experience or bought your touch up at Wal-Mart.
Old Jun 3, 2006 | 07:16 PM
Fizzie06's Avatar
Fizzie06
Or I got lucky with the only bottle of touch up paint in the world that matched almost perfectly.
Old Jun 3, 2006 | 07:52 PM
Daniel60's Avatar
Daniel60
The thickness of the paint is what I am talking about and maybe I do suck at applying it. I'm sure your mother is proud of you.[sm=smiley32.gif]
ORIGINAL: Fizzie06
Old Jun 3, 2006 | 08:19 PM
fairlane292's Avatar
fairlane292
You are right. Touchup in the bottle from the dealer will look like *** when applied. (you don't have paint on the surface of your car) the color is well below and only clearcoat is on the surface; that solution was ok in the early 80's and prior but it's silly now. First of all if one is getting a lot of chips they are putting on a ton of miles and/or following too close. The more tire you can see on the vehicle in front of you the more likely something will kick up and you'll run into it. Stay back is #1, but trucks are the worse and even some cars; a 73 caddy sedan deville will be less likely to kick up anything; heck you can barely see the tires from behind. Get what I mean?
As far as repair, if you have lots of chips just get the car panels redone when you've had enough. For just a few chips there are some kits out there that allow you to essentially apply a base and clear such that it is smooth with the surface. Even if raised a bit from extra clear, before you get the car detailed, lighty wet sand the spot with #2500. The detailer will then buff to what will be barely noticeable, if at all.
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
