Upper Transmission Bolts
I destroyed my clutch in my GT the other night racing and am in the process of installing a new RAM clutch kit and Flywheel. Does anyone have any suggestions on how to get the two upper transmission to engine bolts off? I think with the trans. cross member off, the engine and trans. seem to tip back quite a bit and maybe I can get at them from the back of the trans. Any suggestions?
RE: Upper Transmission Bolts
I found that they can only be removed from the back of the tranny using a long extension with a 13mm swivel socket with the transmission mount removed to allow the engine to tip back slightly.
