Hanging revs
Old Jun 8, 2006 | 10:43 PM
classj's Avatar
classj
Default RE: Hanging revs
Right. On older cars they had solinoids and other devices to keep the throttle plates from closing at high rpms and creating an over rich mixture. The main reason they claimed it existed was to protect the cats. On some cars it was called a catylist protection solinoid.
What we might be expiriencing is the modern equivilant of that feature.
However, the reason for the orginal feature was that with the throttle closed, with the engine at high rpms, it creates very high vaccume in the intake. This is a very strong signal at the carb. Even with the carb plates shut, the engine is pulling hard on the idle feed orifices and slots. Still richening the mixture. And since you cant shut the fuel off in that application, the easiest thing was to keep the throttle open a bit.
But in modern cars, all they have to do is shut off the injectors to kill the fuel. So I dont quite understand why there is a need to keep the engine speed hanging to protect the cat and decrease emmisions. Unless there are other emision problems created by suddenly shutting the throttle on the motor, which there may very well be.
Old Jun 9, 2006 | 05:13 AM
RICAKILLA's Avatar
RICAKILLA
tuner with a canned tune helps wickid good, i installeda C&L Tuner with the Brenspeed tuner and OMG what adiff.!
Old Jun 9, 2006 | 11:26 AM
Speedy's Avatar
Speedy
ORIGINAL: Scooter80
Well, on a GT the TPS is on the left side of the TB as you look from the front of the car. Dunno if a 6 is the same??
EDIT, ooh, just found a V6 diagram. The TPS on the 6 is on the Driver's side of the TB. Go Figure.
[IMG]local://upfiles/31863/EC0BFCFAFC1C41D9A4E0CD13121A5B61.jpg[/IMG]
Scooter - awesome, thanks a bunch for the diagram. Just what I was hoping for. Hopefully I'll get a chance to have a check later on.
Just to clarify - I think there's talk about two types of hanging revs here. The 'standard' one is to reduce emissions from an over-rich fuel mixture going through. It sounds like this can be reduced through a canned tune. I believe that there is a second type (which I'm experiencing) which is probably due to a problem with the TPS - which also happens on other Ford vehicles including the Focus. Most likely to be experienced in a manual, when coasting to a stop in neutral. Rather than revs returning to idle, they will stay at the revs that you have been cruising at on that trip (so around 2000rpms if you've been on the freeway for a while). Revs only return to idle when the vehicle comes to a complete stop. I've sometimes experienced the revs dropping down to idle, then picking back up to 2000rpm, which I suppose is an interim condition with the TPS very confused!
Would be interested to hear if anyone else has had these 2nd types of symptoms - obviously you'd only tend to notice if you shift into neutral before stopping. Blackfoot, I agree with you that the service centre explanation is a bit unsatisfactory - I've become rather cynical of service centres in general and the skill is finding one you trust.
Old Jun 9, 2006 | 11:45 AM
Scooter80's Avatar
Scooter80
ORIGINAL: Speedy
ORIGINAL: Scooter80
Well, speedy, no problem on the diagram. I am also having the exact problem you are describing but am supercharged. I though it might be due to that fact, but since you've heard of the same problem with stock cars, maybe I have the issue too.
Would another symptom be a high idle upon cold start? Like 2500-3000 RPM's that stay there for like 10 seconds? Only happens when the car is dead cold and can be stopped by reversing out of the driveway. A short distance, but once all the way back and then into 1st, the idle has settled down. Weird. I called Procharger on it and they say its normal for a s/c'd car, but I am not believing that.
Old Jun 9, 2006 | 02:09 PM
StartMeUp's Avatar
StartMeUp
My 98 F-150 does this. I know it's not a Mustang but it is a Ford with a 5 speed manual and a 4.6L V8. I always thought they left the revs hang while the vehicle is in motiion and the tranny in neutral so the tranny would be easier to put back into gear if you decided to.
Old Jun 9, 2006 | 03:30 PM
Nadelle's Avatar
Nadelle
LoL funny you should mention the focus, my 04 2.3 zx3 did the same thing maybe like 4-5 times ive owned it in the last 2 years. Thats not enough for me to get worried.
Old Jun 9, 2006 | 04:01 PM
ScottRNelson's Avatar
ScottRNelson
Here's another data point:
I noticed the revs staying up nearly a year ago when I got my car, have complained about it multiple times, and the dealer says there is nothing they can do about it.
I've watched it closely and generally understand what it's going to do. I can be cruising down the road at 35 mph, gently nudge the shifter into neutral, and watch the revs stay at 1800 rpms until I come to a complete stop. Sometimes it's 1800, sometimes 1500, and sometimes 1200, but it stays up there until it detects that the car has come to a complete stop, then it drops right down to 800. If you wait long enough it will come down anyway. It seems to make a difference whether or not you push the clutch in when going into neutral, but only for how high the engine is running.
I find it especially annoying when heading downhill in the mountains and I can't get full engine braking for five seconds or more.
If anyone ever gets Ford to admit this is a problem and provide a fix for it, please let me know so I can get it fixed.
Old Jun 10, 2006 | 05:35 PM
Airborneflyguy's Avatar
Airborneflyguy
yeah, for the most part I think ppl are talking about the emissions deal. Really Really REALLY annoying if you miss a gear...
and I'm not sure if this is at all related but any of you who fixed the hanging idle with a tune...can you shift into first going any faster than 10 mph? I hate that I'm locked out of gear until I make a damn near complete stop. What if I'm at 20-25 in 2nd and want to downshift for a little fun. NOPE!
Old Jun 12, 2006 | 02:30 AM
2006RedGT's Avatar
2006RedGT
How does it stop you from going into 1st? There would have to be some kind of physical obstruction.
Old Jun 12, 2006 | 08:50 PM
Airborneflyguy
dunno but it does. I'm not that savy on how manual trannys work but it is normal...and I hate it
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
firehorse02
Nov 16, 2015 11:28 AM
BeatnikFink
Oct 1, 2015 08:00 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
wraith777
Sep 28, 2015 10:49 AM
