Drive By Wire
Old Jun 12, 2006 | 11:11 PM
  #21
ford4v429's Avatar
ford4v429
Default RE: Drive By Wire
did you try the recalibration thing? turn key on wait for lights to go off, push to floor, immediately release, turn off key.
Mine it seemed to help lag at takeoff, but at lifting pedal it still hangs but at a lower rpm- heck, its worth a try.
only thing about driving the car that could be improved upon- the drive by wire response sucks. Ford should offer a over the counter 'offroad' reflash thats warranty approved- they'd sell a bunch of them. I HATE lifting on the highway- with clutch still engaged I get EXACTLY 6 seconds delay before any engine braking(except for the first 20-30 seconds after cold start on a 60-70 degree day- then if you lift in first it burbles and backfires...wish it always did that
Old Jun 12, 2006 | 11:29 PM
  #22
elektra's Avatar
elektra
ORIGINAL: stangman05
Elektra where do you live in St louis that you can coast to work? I work in St. Louis too. Just curious?
I live and work in Maryland Heights. The fastest street is schuetz @ 40mph between page and Dorsett.
For the rest of you I should explain that the decline is maybe a total of 20 feet over a mile. It is not a hill or even a mound. Very small.
Old Jun 12, 2006 | 11:35 PM
  #23
5 speed GT's Avatar
5 speed GT
This Drive by Wire sucks; I hate it. I have had it cause some serious bucking problems and have downshifted from 5th to 4th and punched when I really needed the power right then and it fell flat on its face. Is there any TSBs about this? Can the dealer do anything to reflash the computer and fix this mess?
Old Jun 12, 2006 | 11:38 PM
  #24
elektra's Avatar
elektra
ORIGINAL: ford4v429
I have not seen this recalibration you speak of. I will try this tonight!
I just tried it again and I have a issue at hand. If I drive (on a empty country road) and drive 45 mph and put it in neutral and drive its starts off at 1400 RPM. The slower I go the higher the revs get. Once at a stop it will hit a peak of 2500RPM until I put in the clutch. Once I release the clutch the rpms will go back up to 2500 RPMs till I take off.
You cant tell me this is normal! It sounds like a software issue from FORD!
Old Jun 13, 2006 | 12:45 AM
  #25
2006RedGT's Avatar
2006RedGT
ORIGINAL: olym4gery
ORIGINAL: 2006RedGT
ORIGINAL: olym4gery
If you have to make an evasive manuever, you should be ready to instantly accelerate.
If there is no one around then there is no reason for this.
Yes, and why wear a seatbelt until you think you might be in a crash.
LOL thats true.
Old Jun 13, 2006 | 12:57 AM
  #26
viking396's Avatar
viking396
ORIGINAL: olym4gery
It's a poor practice.
Next, I'm still thinking the "neutral coasting" is messing with the computer. I don't believe the MT equipped vehicles have transmission sensors. Meaning "Spanish Oak" doesn't know what gear, if any, the transmission is in at any given time. So when the car is "coasting" "Spanish Oak is putting enough fuel into the engine to maintian the car's speed................... against a transmission that isn't in gear.
Braking bias may also be an issue. Although with ABS it's less of an issue. The brakes are "balanced" so that each gets a certain amount of braking force. Because of dynamic weight transfer, front brakes usually do appx 65% of the "stopping" Rears do appx 35%. The brake system should be balanced so that the fronts/rears are using the same percentage of the available traction. So one "axle" doesn't lock before the other. Part of that equation is engine power, supplied as if a AT transmission is in gear, or a MT transmission is in gear while the brakes are applied. Disrupting that balance will cause the brakes to be less effective at stopping the car.
I agree with the manuevering statement but you should be ready to brake too. If the computer was feeding enough fuel to maintane the cars speed it would be well above 2200 rpm's while coasting. As for what the brakes should do, the car would react the same if you had the clutch depressed as it would out of gear in a panic situation. These cars aren't equipped with stability control so assumtions aren't made and the system expects YOU to properly react not the brakes, they simply do there job according to how much pressure is applied to the pedal. Aside from that of course ABS does it's job perportioning wise (sp).
Old Jun 13, 2006 | 05:16 AM
  #27
olym4gery's Avatar
olym4gery
ORIGINAL: 5 speed GT
If you are talking about "hesitation" there is a thread around here about that, and perhaps a TSB. It seems that if you maintain a steady speed for a while, an air bubble forms near the fuel pick-up. When you downshift, and try to accelerate you get air instead of fuel from the tank.
Old Jun 13, 2006 | 05:56 AM
  #28
davidb123456's Avatar
davidb123456
ORIGINAL: elektra
hmm, Interesting. So am I hurting my car with my driving techniques? I heard that it was okay but you go through brakes faster. Anyone else suggest David's veiwpoint?
I didn't mean to suggest you were hurting your car. Nothing logical suggests you're doing that. It's just that I found that a very strange technique - it wasn't a criticism of you, because you've obviously been taught that it's an acceptable thing to do. All I know is that here in the UK where everyone drives a manual and it's culturally ingrained, I've never seen anyone do that and I KNOW that you would fail your driving test if you did that.
As for evasive action, obviously if you're in the middle of nowhere the inability to accelerate isn't a major problem like you said!
BUT I think you heard right that you'll be going through brakes faster. Especially down a hill, when you're driving normally, in gear, and lift off the gas the engine will brake itself; in neutral, it will gain momentum. Obviously, you'll have to work the brakes harder to stop you everytime you brake in neutral/coasting.
So I guess the upshot is, sorry if I sounded rude. I'm sure you're not damaging your car one bit. It's just a very strange driving technique to me - but apparently not so strange to other people who posted after.
Old Jun 13, 2006 | 06:44 AM
  #29
olym4gery's Avatar
olym4gery
David, there's a reason no one in the entire country of England drives like that. There's a reason that anyone who does drive like that would fail their driving test.
Instead of going through all the computer stuff, just drive it in gear instead of coasting, and tell us how that works out for you.
Old Jun 13, 2006 | 11:35 AM
  #30
LarryS's Avatar
LarryS
The only fix is with an SCT Pro Racers Package. You can set your idle to do anything you want.
I couldn't stand the high idle at start up cold or hot. That's an easy fix with the Pro. I'm sure you could fix the high idle at decelerating as well.
