Camber Bolt Question?
The lower hole, however you have the modify the strut... I installed the FRPP suspension pack that lowres the car 1.5 inches and made sure to install the strut with the bolts pushed out as far as possible and a week later when we went to install she was at 1.3 on both sides and tow was only off by 1/16 so we adjusted the tow and I did not install the camber bolts as they were not needed. 1.3 is a nice setting for good tire wear and good performance. The bolts that came with the FRPP kit actually allow you to increase if you were going to race, I don't need that much of an agressive adjustment...
ORIGINAL: 06GT4RAD
So can anyone tell me which hole position the aftermarket camber bolts go in? I am pretty sure it is the lower hole in the strut but want to make sure.
Richard
Richard
