IPOD AUX
Old Jun 22, 2006 | 12:09 AM
  #51
CDW63's Avatar
CDW63
Default RE: IPOD AUX
Jay004f,
What is the peripheral model # for the 06 Ford Mustang? I am not sure my audio store has the correct one...
Thanks,
Old Jun 22, 2006 | 09:19 AM
  #52
vicmeldrew's Avatar
vicmeldrew
ORIGINAL: Anomalus1
oooook.... so it's not tomorrow yet, decided to run outside to see if it's still working and it's not. "No Aux Audio" is displayed. I decide to qwik-fix it by running the wires up through the armrest and having the ipod adapter sitting inside the armrest. When it decides to stop working, i open the box, flip the dip switches a few times (without having to remove the console or radio), it gets working again and hooray. A qwik-fix til a real fix takes place i guess.
how did you get the adapter into the armrest; the wiring harness cable that it connects to does not appear to be long enough to reach the armrest. let me know as i talked to peripheral yesterday and they told me the same thing - they are working or a solution but that will still take some time. thanks
Old Jun 22, 2006 | 09:27 AM
  #53
Anomalus1's Avatar
Anomalus1
ORIGINAL: vicmeldrew
ORIGINAL: Anomalus1
i didn't think it did either, but i kept pulling and it kept coming out with out any resistance. Either the guys that wired my car accidentally gave it too much or i'm messing something up, but it appears nothing has gone wrong... yet...
Old Jun 22, 2006 | 09:41 AM
  #54
quietcoolone's Avatar
quietcoolone
Anomalus1,
Sorry if i did not make a clear request.. what i'm asking is to permanently disconnect the 16-pin connector from the radio-- leave the 24-pin in place-- test it in this matter to see if the radio continues to recognize the PXDP2. Then advise those of us in the waiting!
Thanks
Old Jun 22, 2006 | 09:49 AM
  #55
Anomalus1's Avatar
Anomalus1
ORIGINAL: quietcoolone
Anomalus1,
Thanks
Ah, i gotcha, i'll give it a try, may take a while before i reply. will have to let it sit a bit to see if it works.
Old Jun 22, 2006 | 10:00 AM
  #56
vicmeldrew's Avatar
vicmeldrew
Anomalus1,
Thanks
i also understand what you are asking and would only consider this a temporay solution - for the price we paid for this piece + - $185 i expect it to work correctly as i do utilize the speed volume control- really comes in handy with a convertible with the top down due to all the other noise we get from outside sources. strange that these manufacturers were not aware of this problem with the earlier issues.
Old Jun 22, 2006 | 11:09 AM
  #57
jay00f4's Avatar
jay00f4
CDW63 The part number is PXDP2 and PXH2FD1. They are brand new and only started shipping last week.
vicmeldrew I stated before they did hours of testing on these cars but didn't have the opportunity to have them overnight. Ford doesn't provide any assistance in making these adapters. They have to reverse engineer them completely and make them interface into a Sat. or CD changer port. Things the radio wasn't made to do. There will always be little issues that have to be ironed out in the beginning. They will have a solution soon and take care of the issues that anyone has had. Sorry for the inconvenience.
Old Jun 22, 2006 | 11:24 AM
  #58
jay00f4's Avatar
jay00f4
OK, I just spoke to Peripheral. They said they were able to learn some things in the Mustang they rented. They are going to do some more testing in the next few days to make sure it is good. He also said in the mean time if you want to connect the interface box to Accessory and not to Constant 12v it would cause the box to power up new everytime you start the car and it would recongnize it. The only negative to that is it won't charge the ipod when the car is off. Not a big deal for me because I never leave mine in the car. Apple even tells you not to leave it in the car beacause the heat and the cold will shorten the battery life.
Hope this helps
Old Jun 22, 2006 | 11:29 AM
  #59
quietcoolone
Vic,
You are right-- the suggestion made was a temporary solution-- if it works it would be more convenient than disconnecting and reconnecting. - I heard PIE's auxiliary input had the same issue with Mustangs and disconnecting the 16-pin cable resolved the issue until a permanent solution was available.
Do you think Peripheral knew there was a problem with Mustangs?
I don't think so, otherwise they would have omitted the Mustang.
We know this is not what you and others have paid for, however you guys can go back to the store and request a refund or wait until a permanent fix is available-- I'm sure the dealer from which you purchase this part will work with you. Fact is, the pxdp2 does work in some Mustangs but has this issue in others.
There is no need to panic-- i'm yet to see first generation product that was problem free -- there is always some unforeseen issue and the PXDP2 is not the exception.
Lets wait and see what Anomalus1 finds out.--
Old Jun 22, 2006 | 02:13 PM
  #60
speed deamon's Avatar
speed deamon
s
