How to adjust the clutch play -quadrant?
I was told the new Mustangs come with an adjustable quadrant. I am not happy with the release as it is right off the floor and it cannot be feathered. Where is it and how do you adjust it?
RE: How to adjust the clutch play -quadrant?
What you are going to need to do to fix this is get a cable adjuster and a new quadrant installed. Steeda makes a good one, and it's not expensive. This will allow you to set the disengagment point in the pedal travel to wherever you want it. That's the only fix.
Don't trust me?
Your car has a hydrolic clutch. It is basicly unadjustable (self adjusting). The manual cable allows you to set the disengagment point wherever you want it. Also, your car uses a crappy, plastic quadrant. Steeda makes a double or triple hook billet quadrant that will also help to improve the feel of the pedal.
junior04
09-28-2015 10:53 AM
