Lowering pains...
Old Jun 22, 2006 | 06:20 PM
newbikerider2003's Avatar
newbikerider2003
Default Lowering pains...
After installing lowering springs on your car, how many people had to go buy a different jack with low profile? I have access to a 4 piont lift, but it's useless. My stock 05 GT sits too low for the arms to swing under the frame. When I slide a floor jack under, I have to make 50 of those little pumps before frame contact. There is a jack that lifts fast on the first pump then slow as weight builds. I also don't feel the lift pionts shown in the book are stiff enough. During my last oil change it squeaked too much as I lifted it just to get the plug out.
Old Jun 22, 2006 | 08:06 PM
2nd II None's Avatar
2nd II None
Default RE: Lowering pains...
Time to make some 2x4 ramps!
Old Jun 22, 2006 | 08:12 PM
bl1nk's Avatar
bl1nk
ORIGINAL: 2nd II None
Wish I could do this out of metal but I wouldnt even know where to start...
Old Jun 22, 2006 | 08:36 PM
RICVA05's Avatar
RICVA05
I had to buy a low profile alum. jack from Northern tool right after I lowered mine. Jacking the rear up is no problem. For the front I jack it up from the main support beam at the front of the engine at the back of the plastic shroud the beam is covered by the plastic so you got to make damn sure your jack is under that beam. http://www.northerntool.com/webapp/w...3355_200313355
Old Jun 22, 2006 | 09:27 PM
05ROUSHER's Avatar
05ROUSHER
I bought my floor jack from Summit. Aluminum, weight is about 30# and is has a capacity of 3000#'s Works great. And it was only $80.00 + 0r - a couple.
Old Jun 22, 2006 | 09:29 PM
Hiboost's Avatar
Hiboost
Pepboys has some small metal lifts that you can drive on to get a jack under the car. They even come with a nice bag to keep them in.
Old Jun 22, 2006 | 09:33 PM
05ROUSHER's Avatar
05ROUSHER
I'm also seriously considering getting a Kwik Lift System. They are around $1400. But you just drive the car on it and use your regular floor jack to raise it up and set the support legs.
www.kwiklift.com
Old Jun 22, 2006 | 11:28 PM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: RICVA05
That's the same one i got. It is a badass jack to. Check the site for Torin Jacks they have a few differant styles.
Richard
Old Jun 23, 2006 | 06:26 PM
fairlane292's Avatar
fairlane292
ConsumerAutoParts (CAP) had their "lowrider" on sale a week ago; I think it was $129; I believe you only needed like 2 3/4" to get her under there.
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
